02-20-2008 02:32 AM - edited 03-15-2019 08:57 AM
I am not able to edit the TFTP server key in my IP phone ( want to register it to another CCM). After pressing **#, the message is " that key is not active here". This used to work in my previous organization. Anything I need to change anywhere?
Solved! Go to Solution.
02-20-2008 02:41 AM
Have you checked "DHCP Enabled" field. It should be set to "No" to be able to edit IP/TFTP details
02-20-2008 02:41 AM
02-20-2008 03:13 AM
Anand,
Thanks a lot. It's fixed now. Have a nice day.
Abhijit Das.
