mismatch timers RIP
Feb 20th, 2008
Hello;
I want to reduce rip timers about point- to point interfaces to multipoint interface central router.
is it possible to have different timers in the two routers? May I have any problem? ¿Can it bring me loops?
These are my configurations:
Remote
interface ATM0/0.1 point-to-point
ip address x.x.x.x 255.255.255.0
router rip
version 2
timers basic 20 45 45 45
Central
interface ATM0/0.1 multipoint-to-point
router rip
version 2
Thanks .
arun kumar Wed, 02/20/2008 - 03:41
  • Bronze, 100 points or more
I faced packet drops to the destinations when i had RIP timer mismatch between two routers though i didn't have any problem in learning the prefixes.
HTH...
Julio Carvajal Sun, 03/31/2013 - 13:28
  • Purple, 4500 points or more
Well that depends, as an example I did the following
11.11.11.0----Router1----12.12.12.0---Router2---13.13.13.0
All of them are /24.
On router 1 I set the following timers
Router rip
timers basic 10 60 60 60
on Router 2
router rip
     timers basic 100 180 180 180
So as you can see Router 1 will send RIP messages every 10 seconds and it expect to receives an update before 60 seconds, if not it will mark the route as invalid on not accesible
                         X.X.X.X is possibly down,
On the other hand the updates being received on Router 2 will be fine as R1 will be sending updates every 10 seconds,
So as you can see you definetly can cause some problems if you configure the routers on a way that you can break things,
Hope that I understood the question
