Compatibility SSL and ASA
Answered Question
Feb 20th, 2008
We want to buy a certificate SSL to change the actual certificate in ASA. Are there any requirement or specific type of certicate compatible with ASA?
Correct Answer by m.sir about 9 years 3 months ago
Check this document
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00808a61cd.shtml
Supported 3rd party CA vendors are Baltimore, Cisco, Entrust, iPlanet/Netscape, Microsoft, RSA, and VeriSign. So if you want some support from Cisco it should be some certificate from those vendors but we successfully used also certificate from other vendor.. Generally it should be any X.509 certificate
M.
hope that helps rate if it does
Overall Rating: 4 (1 ratings)
Correct Answer
m.sir Wed, 02/20/2008 - 05:13
  • Gold, 750 points or more
Check this document
M.
Phil Williamson Wed, 02/20/2008 - 05:33
I was just about to ask this same question. I contacted GoDaddy and they said they did not have a cert to support the Cisco ASA. Would you share your experience with the rest of us X.509 newbies?
With an ASA5505 at < $1000 its difficult to justify a $500+ cert.
