Rob Huffman Wed, 02/20/2008 - 05:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Naser,
Sadly, the WLC 526 only supports the LAP 521. No other AP Models can be used in this solution.
Q. Which access point products are included in the Cisco Mobility Express Solution?
A. Two Cisco 500 Series Wireless Express Access Point products are in the Cisco Mobility Express Solution; their part numbers follow:
• AIR-AP521G-x-K9 (standalone access point)
• AIR-LAP521G-x-K9 (controller-based access point)
The hardware for these products is the same. The products have different software, but the access points can be converted from standalone mode to the controller-based mode with a simple software upgrade.
http://www.cisco.com/en/US/prod/collateral/wireless/ps7306/ps7319/ps7338/prod_qas0900aecd8060c860_ps7320_Products_Q_and_A_Item.html
As a core element of the Cisco Mobility Express Solution, the mobility controller is built to specifically support the Cisco 500 Series Wireless Express Access Points.
http://www.cisco.com/en/US/products/ps7320/index.html
Hope this helps!
Rob
ndiab Wed, 02/20/2008 - 06:52
Ok, What if I've the AIR-WLC2006-K9 controller, Can the LAP521 be managed through this controller
