Variable7
Answered Question
Feb 20th, 2008
Hi All;
I have an ODBC Gateway node in my script, I need to know what the variable7 value is coming when doing the call from specific telephone number, how can I see it?
Bilal
Correct Answer by kre8or2007 about 9 years 3 months ago
If you go on the Logger, SQL Query analyzer, under user tables, there is a dbo.t_Route_Call_Detail that you can look in. This works for ICM 7.1.2.0 through 7.1.5.0 anyways.
Overall Rating: 5 (2 ratings)
Correct Answer
kre8or2007 Wed, 02/20/2008 - 06:08
bilalghayad Thu, 02/21/2008 - 01:27
Big thanks, it worked fine.
Do u know how can I know who is currently logged in to a specify skill group (which agents)?
Bilal
kre8or2007 Fri, 02/22/2008 - 06:54
Real time reports or supervisor desktop should work if you have those features.
bilalghayad Sat, 03/01/2008 - 14:03
Real time reports u mean the webview reports, correct?
Bilal
