Voice quality very poor
I have Wireless LAN (WLAN) which comprises of PCs and IP wireless phones.
Infact, I have six Cisco Aironet 1200 series Access points. one per each room and Avaya Voice Priority Processor which prioritises voice traffic on the WLAN.
There are only three wireless IP phones and 3 PCs per room.
The voice quality is good when two users are on phone. however, the quality becomes very bad when the third user is also on phone.
Any ideas on why quality becomes very bad when the third user is also on phone.
Also what can be done to rectify the voice quality problem.
john.preves Fri, 02/22/2008 - 18:17
  • Silver, 250 points or more
Does it become poor voice quality for everybody or just the third guy?
Are you certain you are associated to the AP you think you are or you associated to one a couple of rooms away?
For the wireless side I would lower the power on both the AP's and the phones. The object is to keep that AP's cells from bleeding over too much into the next cell. You may have to remove AP's.
Three users per AP should not be taxing the network. A voice call is like 8k or something really low like that after the initial 'hello'.
I would keep the data rates locked at 11Mbps unless I absolutely had to drop them to 5.5Mbps (some phones require a lower data rate to connect...)This keeps the cell sizes controllable.
Check both the wireless and the phone side for any configuration mistakes...
Something to think about anyway...
