LMS 2.6 and ACS Integration - Version Compatability
Feb 20th, 2008
I have a customer who is currently running ACS ver 3.2.2 build 5 and has just installed a LMS 2.6 (CS 3.0.6) system.
They are looking at integrating the two systems together.
I have spent a lot of time trying to confirm that these two software packages/version are compatible (without any success).
Can anyone confirm that LMS 2.6 will work with ACS 3.2.2b5?
On a more general note, can anyone point me to a document that identifies the officially supported versions for LMS and ACS integration. (I am sure the next question will be that if 3.2.2b5 is not supported, then what version is)
Thanks in advance
Mark
Joe Clarke Wed, 02/20/2008 - 09:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Initially, LMS 2.5 support ACS 3.2, 3.2.3, and 3.3.2 (http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.0/installation/solaris/guide/rmeacs.html). However, ACS 3.2.2 (and really all of 3.2) had some pretty serious bugs. While it will work, you should really be running ACS 3.3.2 or higher.
The current versions supported are those I listed above as well as 3.3.3, 3.3.4, 4.0, and 4.1. Both appliance and host base versions are supported:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_common_services_software/3.1/user/guide/overview.html
