MGCP E1 on cat6513 with WS-SVC-CMM
Feb 20th, 2008
How do I have to do to configure E1's using MGCP on a catalyst 6513 with a "WS-SVC-CMM" module?
Jaime Valencia Wed, 02/20/2008 - 10:43
Device -> gateway -> Add New -> Cisco Catalyst 6000 E1 Voip Gateway -> Next
the config on the module is almost the same as with a T1, it just changes the voice-port number that gets created and the pri group timeslots as well
How to Configure MGCP with Digital PRI and Cisco CallManager
francois.staiesse Thu, 02/21/2008 - 04:18
When I add such a gateway in the CCM admin, it requires a MC address.
What's this MAC address and how could I find it?
Jaime Valencia Sat, 02/23/2008 - 12:33
Sorry, my bad, you need to select when adding the GW Communication Media Module and not CAT 6000 E1. The option i mentioned was for a 6608 and not for a CMM. if it was a 6608 then it would be the MAC from the port you will use
rob.huffman Wed, 02/20/2008 - 10:55
Hi Francois,
As nicely noted by Jaime, the majority of cnfig is done on CCM itself :) Here are some related docs;
Adding Gateways to Cisco CallManager
Adding a Cisco IOS MGCP Gateway
How to Configure MGCP Gateway Support for Cisco Unified Communications Manager
Catalyst 6500 Series and Cisco 7600 Series Communication Media Module Installation and Verification Note
Hope this helps!
