Unified Communications Manager
Feb 20th, 2008
Customer is asking for two timers:
1 - for call lenght restriction - restrict one type off call en "local calls" to have a maximum length in minutes.
2 - after a call is dropped a timer to complete a call for the same number after a call to a specific number is dropped another try need to wait X minutes.
Is this possible in any version?
Is this possible for CUCM 4.2?
Should this be configured in some dial-peer as any kind of timer?
Tommer Catlin Wed, 02/20/2008 - 12:41
I would probably reverse engineer this through policy and procedures.
Using CDR, you can do monthly or daily or whatever reports that will pin point your problem people. If the policy states calls are limited to xx, the report shows people going over, corrections can made to these users of the system.
CallManager limits calls by Call Adminssions Control. But this is more for calls between sites. For instance, I can limit the number of calls between sites, but not the duration of the call.
In this post, the service parameter will be cluster wide, not per phone.
There may be a third party tool, but I have not seen one.
