Personal Assistant and CUCM 6.0
Feb 20th, 2008
I have a customer with the Personal Assistant, the CCM 4.2, and the unity 4.x. This costumer wants to migrate to the 6.0 version, but as far i know, the PA is not compatible with this application. I want to know if there is a solution to implement the fetaures of the PA (personal call rules for example) in the new version of the CUCM 6.0 with the support of the Unity.
Thank you
Ginger Dillon Wed, 02/20/2008 - 11:34
Hi -
I'm not 100% sure, but I think the Personal Assistant features were being moved into Unity 5.X with a server called Voice Recognition Server. It is built from the Unity 5.X CD on a separate production server. I only have experience with it in a test lab configuration. Here is the 5.X installation guide reference to the server's install - and to the application System Admin guide -
alvdelafuente Thu, 02/21/2008 - 00:22
Thank you for your response.
I am intersting in the the feature of the personal call rules overall. The document refers that this feature has been implement in the Unity 4.x, but i do not find a document that explains how to migrate step by step.
debhendon Fri, 05/16/2008 - 08:35
I am facing the same issue where we want to upgrade CCM 4.1(3) to 5.x. I just found a compatibility matrix on cco that references PA 2.0(2) that will allow you to take CUCM to 6.x. However, I only find up to PA 1.4(6) on the downloads page. Does anyone know where to find it? Here is a link to the doc (see Table 36):
