incoming call config on VIC2-2BRI-NT/TE
Feb 20th, 2008
ive installed VIC2-2BRI-NT/TE module on my voice gateway where my cme/cue resides.
OBJECTIVE;
-Incoming call will connect directly to an extension 100 but after 5 rings is finished, then it shoud procced to the cue auto attendant 101.
Anyone help me for the configuration please
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Wed, 02/20/2008 - 09:39
voice-port x/y/z
connection plar 100
ephone-dn 100 dual-line
number 100
call-forward noan 101 timeout 30
You can simplify configuration by placing common call forward settings under an ephone-dn-template, and apply the latter to all or groups of ephone-dn's.
Hope this helps, please rate post if it does
