Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1919229members
1223409discussions
Community Activity
Not seeing debug dot1x or mab event log entries on IOS-XE machines.
Hello all,20+ years ago I used debug all the time, however not so much so in the last decade. Seems like last time I called TAC on the 3850 debug command they gave me some silly answer that debug was a Cisco TAC command.  WFIW All the Cisco.com debug...
wags by Level 1
  • 71 Views
  • 2 replies
How Do I Talk to Human at Qatar airways? Speak with live representativ
헤헮혁헮헿 헔헶헿현헮혆혀 s phone number to call and talk with a live 헿헲헽헿헲혀헲헻혁헮혁헶혃헲 fast is ퟭ-ퟮퟬퟵ-ퟰퟰퟱ-ퟮퟲퟬퟬ // ퟭ-ퟮퟬퟵ-ퟰퟰퟱ-ퟮퟲퟬퟬ. Select your connection language upon call and choose the IVR option that best suits your query by looking through the ones that are gen...
How Do I Connect With People on Aeromexico 𝗔irlines ? 【24^7𝗙𝗮𝘀𝘁 }
헔eromexico 헔헶헿헹헶헻헲's phone number to call and talk with a live 헿헲헽헿헲혀헲헻혁헮혁헶혃헲 fast is ퟭ-ퟴퟬퟱ-ퟯퟮퟳ-ퟲퟴퟱퟴ // ퟭ-ퟴퟬퟱ-ퟯퟮퟳ-ퟲퟴퟱퟴ. Select your connection language upon call and choose the IVR option that best suits your query by looking through the ones that ar...
Modelo OSI e suas Camadas
Você sabia que, o modelo OSI é um modelo padrão de comunicação entre sistemas de computadores e redes?    É isso mesmo ele faz uso de sete camadas cada uma com funções específicas, que permitem que os dispositivos de rede se comuniquem de maneira efi...
Resolved! PSA: Avoid CBS350 Switches - Critical POE Defect
Hello Community, I'm writing to let you know that there is a critical POE defect in the CBS350 switches and you should avoid them if you require stable POE operations. This apparent software defect causes POE ports to randomly fault after 8 to 12 hou...
d0nni3q84 by Level 1
  • 18088 Views
  • 49 replies
Resolved! SFP inventory from ACI Fabric
Hi all, I need to inventory the SPF plugged in the SPINE and LEAF of our ACI Fabric, but didn't find a menu where i can check that information, Anyone knows if is it possible to get that information consolidated? Our Fabric is version 2.1(2g)   Thank...
EduardR by Level 1
  • 12226 Views
  • 12 replies
Error ISE and Duo
Hey guys, VPN on Firepower authenticating on ISE -> OK VPN on Firepower authenticating on Duo -> OK VPN on Firepower authenticating on ISE calling external Radius (Duo) for MFA -> NOK   Duo's auth proxy logging shows: "20): Cannot decode password usi...
SAML include all AD groups
We are looking at moving to SSO but need to be able to include all the groups a user is a member of. Is it possible to pull this from AD and include it in SAML claims?Ideally we would want to manage this in a single place (AD) so if we added a new gr...
sv45354 by Level 1
  • 25 Views
  • 0 replies
BGP between two remote FTD
I have two Firepowers in two remote offices and i have two ISPs in each office, i had configured vti ipsec vpn between two offices but they are working with static routes, can i configure dynamic routing protocols for failover vpn? I tried to configu...
Resolved! Replacing spine by a different spine model
HELLO, i have cisco aci fabric with many pords, one of my pods are made by 2 x Cisco Nexus 9332C spines connecting 16 leaves with 4 uplinks for each leafs.I already used all the ports of the spines and i want to replace the 32 ports Cisco Nexus 9332C...
ANAKIN_TN by Level 1
  • 691 Views
  • 8 replies
  • 1 Helpful votes
7975 & Plantronics HS-50/APC-42 issue
I am running a CME 12.0 system and I have a Plantronics HS-50 headset with the APC-42 module to control answering and hanging up.  The answering works fine as long as the HEADSET light on the phone is not lit.    However, when the HEADSET light IS ON...
Resolved! ISE admin Group AD users
I have created an external admin group in ISE, which is pointing to an AD group. There are several users in this AD group.Will all the users in this AD group gets ISE admin access or can it be restricted to few users.
manvik by Level 3
  • 104 Views
  • 4 replies
Resolved! ASA Firewall Interfaces Issues (FIREPOWER2100)
Hiin the office where I work, we have an old Firepower 2100 firewall with 16 interfaces,8 ethernet and 4 fiber. So far we have only used 2, one inside and one outside.Now I need to add a server on another ethernet port to be able to reach it via ipse...
Requesting / granting access
I and my teammates make use of the "Screen capture" ability Webex.   I can see some other peoples images, but not others. No one can see my images.   Is there a troubleshooting guide we can go through to find the answer ?This is interfering in our ab...
datpa by Level 1
  • 23 Views
  • 0 replies
