CM6.1 web interface issues
carl.arce
I'm having strange issues after my first CM4.2 to UCM6.1 upgrade, every time I try to list on screen more than 100 ip phones using the new UCM6.1 web interface, I get some blanks on the last 15 or 20 phones displayed, so I have to be more specific or reduce the search to 50 or less items. I'm using the last IE.
Other strange issue is for example if a new extension has the number 2345 I continue to see it unregistered although I just finish to refresh and click the find button again and again, but if change the screen filter to show all the extensions beginning with "234" after that I get the 2345 registered. So I think these issues are a bug?
Rob Huffman
Hi Carlos,
These issues are almost certainly related to Bugs. Here is one very similar 6.1 example;
CSCsl70392 Bug Details
Status & IP not properly associated on Find & List Phone Page
Symptom:
Under Device > Phone the Status and IP address are not properly associated with the correct devices in the list when multiple devices are listed.
Conditions:
CUCM prior to 6.1.1.2104 performing a phone search that returns multiple results.
Workaround:
View the device status on the Phone page, or narrow the search so only a single phone is displayed.
1st Found-In
6.1(1.9901.11)
Fixed-In
6.1(1.9901.52)
7.0(0.39000.33)
6.1(0.39000.19)
6.1(1.2104.1)
You should contact Tac for sure.
Hope this helps!
Rob
Rob Huffman
Hi Carlos,
Symptom:
Conditions:
Workaround:
1st Found-In
6.1(1.9901.11)
Fixed-In
6.1(1.9901.52)
7.0(0.39000.33)
6.1(0.39000.19)
6.1(1.2104.1)
Hope this helps!
Rob
Thanks Rob, could you tell me how can I get a fixed-in version? Should I call TAC or could I download it directly from web? I see you post a "7.0" fixed-in version, is a CM7.0 available now?
Carlos.
