02-20-2008 12:39 PM - edited 03-03-2019 08:47 PM
Hello all,
We have a 1721 at a remote location, and a 2821 at our local site. We are trying to get the remote site to call in and connect to our local site via ISDN. The 1721 has a BRI interface. The 1821 has a PRI interface.
The 1721 ISDN connection attempt almost immediately dies. The 1821 does not even receive any traffic coming in. Both circuits have been tested and verified by the ISPs.
It seems that I am missing something in the config.
I am attaching the config of the remote router that is trying to initiate the connection, the config snippet of the local router that is supposed to receive the connection, and the ISDN debug outputs/status of the remote router.
I have a ticket open with TAC, but they have not been very helpful so far. Does anyone notice anything wrong/missing in the configs? I find it reasonably hard to believe this is a problem with the ISPs at this point.
02-20-2008 01:14 PM
Dave
I have looked at what you posted and I believe that I see several things that would be problems (such as the fact that the remote router does not configure ppp authentication on its BRI while the local does have ppp authentication) but I do not believe that you have yet gotten to the point where that would be an issue.
In looking at the output that you posted I am focused on this:
*FEB 20 8:38:13.991: ISDN BR0 Q931: DISCONNECT pd = 8 callref = 0x86
Cause i = 0x84A2 - No circuit/channel available
Signal i = 0x03 - Network congestion tone on
That appears to me to indicate that there is an issue between your router and the ISDN switch.
Rick
02-21-2008 01:03 AM
Hi ,
Can you change the config as per below and check the issue.
Local Router :
username XXXX(Remote rouetr name) password XXXXXX
controller T1 1/0
framing esf
linecode b8zs
cablelength long 0db
pri-group timeslots 1-24
interface Serial1/0:23
description ISDN PRI circuit xxxxx
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type primary-5ess
no peer default ip address
no cdp enable
ppp authentication chap
ppp multilink
interface Dialer1
description ISDN connect to REMOTE_RTR via xxxx
ip address 192.168.30.5 255.255.255.252
encapsulation ppp
dialer pool 1
dialer caller xxxyyy1384
dialer caller xxxyyy1390
dialer-group 1
dialer-remote name Remote router
no cdp enable
ppp multilink
dialer-list 1 protocol ip permit
Remote router :
username local router password XXXX
interface BRI0
description ISDN connect to LOCAL_RTR via xxxx
ip address 192.168.30.6 255.255.255.252
encapsulation ppp
dialer idle-timeout 300
dialer string 1xxxyyy6101(Local Router number)
dialer-group 1
isdn switch-type basic-ni
ppp multilink.
On both the routers u haven't mentioned username and password as you are using chap authentication for ISDN.
Check the switch type configured on the routers is same as that of configured on ISP's switch.
Satish
02-21-2008 07:52 AM
Thanks, I was not really worried about PPP right now - because like you said it is not even getting to that point.
Satish, your config suggestions make sense... but you think I should remove the SPIDS on the remote router BRI0 interface?
I am going to see what happens with the updated config.
ISDN switch type has been verified by the service providers.
I dont think this is a connectivity issue between the router and the demarc, because layer 1 is saying "ACTIVE", and layer 2 is showing "MULTIPLE_FRAME_ESTABLISHED"
02-21-2008 11:10 PM
Hi dtecco,
I agree with you that Layer 1 and 2 are showing as Active and Multiple_Frame_Established but Layer 3 is not because that is where the ISDN call is being disconnected.
The Disconnect cause code of 0x84A2 means:
84 The public network near the remote user (remote telco switch)
A2 - No channel available - The connection fails because no appropriate channel is available to take the call.
Try the configuration suggested first and if it still fails with the same disconnect code, contact your ISDN provider.
