Multiple networks behind EzVPN DVTI (client)
Feb 20th, 2008
When using EzVPN with DVTI you're not able to have multiple networks behind the EzVPn client, beside connected networks. I need to-way communication between the EzVPN client and EzVPNserver.
I'm using 7200 at headend and 831 remote sites.
The solution for now is Static VTI (SVTI) but then you need to create additional crypto-maps.
Anyone who knows if Cisco is comming with a new feature to add multiple networks for EzVPN DVTI ?
kim.skotte Thu, 02/21/2008 - 11:23
No need for crypto maps, you only need to create a tunnel interface and use the routing table to send traffic to the tunnel interface.
