ANM 1.2: "configure device error: null" when generating a CSR
Feb 20th, 2008
I have a problem with ANM 1.2. When I navigate to Config-> [chassis] -> ACE module -> [context] -> SSL -> Keys, select a key, click on "Generate CSR..." and confirm with "OK" , I get the following error:
"Failed to deploy config to device: Configure device error: null"
At the same time, the following message is written to /var/lib/anm/events/20080220/dev/main.20080220.dev.0.txt:
DEVLOG; ERROR; ; ; ANM; 08-02-20 16:22:25.865; 804; anm1.xxx.yyy.ca; com.cisco.nm.dcm.dal.server.DiceServer; ; ; ; 2; ; 2; ; 2; ; Exception for configDevice:null;
Credentials are OK because everything else works (importing / syncing / polling etc.). Am I missing something? Should I open a case with TAC?
By the way, I wonder why all the logs are in /var/lib instead of /var/log! ;-)
Marc.
