7940 Phone with Logo/Watermark
pritchda78
I am trying to figure out how to setup a watermark or logo-background on a 7940. I have configured the Idle image, but I need to see the line extensions this covers up. I am currently using CCM4.1, but upgrading to 4.3 shortly.
that thread is only for 7970s, the procedure does not apply to 7940s due to the resolution and screen size not being the same
think you already have this:
Creating Idle URL Using Graphics on Cisco IP Phone
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a00801c0764.shtml
you can check this page:
http://www.ccmstuff.net/
there are some services that show images and might be what you're looking for
java
if this helps, please rate
This answeres my question, we can't have a true wallpaper/watermark on a 7940. I'll just stick with the Idle pic and hope for an upgrade or my company to buy a thousand 7970s!
Thanks for the help.
actually you can have a wallpaper in 7941's and 7961's also
of course it's not as fancy as a nice colored big screen as with the 797Xs but you can also configure a background for those models
less resolution and only grey-scale but it's an option
java
