AFAIK the information is kept separate in each, one is the USER directory and the other is the CUCM DB.
there are some scripts in the pages and in CAR that join the information from both to display it or to push it into the DB
if you look into CDR that's raw data, if you look into ART when the upload process runs the info from CDR and directory is combined and now you see DN and who owns it.
java
if this helps, please rate
