ALCATEL---QSIG---CCM Message not compatible with call state
Feb 20th, 2008
Hi, I have a qsig to receive extension from alcatel and is working fine receiving call on iphone, unity too, but on ivr not working, neither attendant console, seem to be redirect number, because for example if phone from alcatel dial to a member of console, the call is conected but if dial to pilot point not working. and the similar problem on ivr because the route point of ivr make a redirect to cti port
I have captured the log on gateway
*Feb 21 03:05:26.918: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x07D6
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18391
Preferred, Channel 17
Calling Party Number i = 0x0081, '1897'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '8888'
High Layer Compat i = 0x9181
Locking Shift to Codeset 5
Codeset 5 IE 0x32 i = 0x81
*Feb 21 03:05:26.938: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x87D6
Channel ID i = 0xA98391
Exclusive, Channel 17
*Feb 21 03:05:26.954: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x87D6
Facility i = 0x9FAA06800100820100A10B0201010201018003495652
Progress Ind i = 0x8088 - In-band info or appropriate now available
*Feb 21 03:05:26.958: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x87D6
Connected Number i = 0x0083, '8908'
*Feb 21 03:05:27.030: ISDN Se0/0/0:15 Q931: RX <- STATUS pd = 8 callref = 0x07D6
Cause i = 0x80E31C - Information element not implemented
Call State i = 0x04
*Feb 21 03:05:27.034: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x07D6
*Feb 21 03:05:27.038: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x87D6
Cause i = 0x80E5 - Message not compatible with call state
*Feb 21 03:05:27.090: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x07D6
Cause i = 0x809080 - Normal call clearing
*Feb 21 03:05:27.102: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x87D6
sdeltoro1 Thu, 02/21/2008 - 16:08
thanks, it is working now, was the asccii name, and display, using blank field worked it,
so but the calling name is not working on?
i'm using mgcp and ios
flash:c2800nm-spservicesk9-mz.124-15.T1.bin"
any ideas?
Paolo Bevilacqua Fri, 02/22/2008 - 04:42
sorry I can't help much when mgcp is used, but I know there is a setting in CM about the qsig version to be used, and few other options as well.
