Help with my cisco 1100 series access point
Feb 20th, 2008
i put wrong firmware, then that led light say ethn: green status: flashing green radio: 1 time red flash and 2nd time red flash every time. what i do with my AP?
rob.huffman Thu, 02/21/2008 - 15:55
Hi PS3,
Maybe we can reset this to defaults using this method instead;
Using the MODE button
You can use the MODE button on the access point to reload the access point image file from an active Trivial File Transfer Protocol (TFTP) server on your network or on a PC connected to the access point Ethernet port.
Note If your access point experiences a firmware failure or a corrupt firmware image, indicated by three red LED indicators, you must reload the image from a connected TFTP server.
Note This process resets all configuration settings to factory defaults, including passwords, WEP keys, the access point IP address, and SSIDs.
Follow the steps below to reload the access point image file:
Step 1 The PC you intend to use must be configured with a static IP address in the range of to
Step 2 Make sure the PC contains the access point image file (c1100-k9w7-tar.default) in the TFTP server folder and the TFTP server is activated. For additional information, refer to the "Obtaining the Access Point Image File" and "Obtaining TFTP Server Software" sections.
Step 3 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 4 Disconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point.
Step 5 Press and hold the MODE button while you reconnect power to the access point.
Step 6 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds), and release the MODE button.
Step 7 Wait until the access point reboots as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 8 After the access point reboots, you must reconfigure the access point by using the Web interface, the Telnet interface, or IOS commands.
Hope this helps!
playstation3 Wed, 03/05/2008 - 20:00
OMG i cant log on a Access Point on website. that website say unable connect to
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
