is it a possible MHSRP with Multicasting traffic
Feb 21st, 2008
Hi all experts,
now site A and Site B are running HSRP no problem. i need to pass through the multicasting traffic between two sites. is it a possible to do? if the answer is possible, can i follow this link
http://www.cisco.com/en/US/tech/tk828/technologies_tech_note09186a0080094aab.shtml
any advise?
attached config files
Richard Burts Thu, 02/21/2008 - 04:44
Other than the issue in the link that you posted with static routes for PIM neighbor pointing to an HSRP address I am not aware of issues running multicast routing on routers running HSRP.
I have configured multicast routing on routers running HSRP and it has worked very well.
Rick
