ACS 4.1 problem gen self-signed cert
Feb 21st, 2008
I have ACS 4.1 installed on a Win2003 server. When I try to generate a self-signed certificate to be able to use https, then java applet stop to function.
Pls advice what could be the problem? does anyone know?
ACS: Release 4.1(1) Build 23
JRE v1.4.2_04
thanks,
Lina
Overall Rating: 5 (1 ratings)
Jagdeep Gambhir Thu, 02/21/2008 - 05:38
  • Red, 2250 points or more
Never seen any issue like this. Is it service pack 2 ? Make sure acs address is added in trusted sites in IE settings.
~JG
linawillerstrom Thu, 02/21/2008 - 06:22
Seems like it is a windows AD-problem. every 30 min the server gets an gpoupdate (depending on who is logged in to the server) and if i have unchecked the box "use proxyserver" (IE - Options - connections - Lan settings) this update changes everything back to default, ie checks that box back. So next step: talk to some windows-people.
thanks anyway!
/lina
