How to Configure accounting on ACS 4.1
jesper_fr
Can someone help me to configure accounting on a ACS 4.1. ?
I have typed these commands in the router :
aaa authentication login default group tacacs+ enable
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
Under "accounting and activity -> TACACS+ Accounting" i can't see any accounting information.
Any god ideas to what i do wrong ?
m.sir
Level 7
Level 7
You configuration looks fine
it looks you are hitting the bug what is in version 4.1
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.1/release/notes/RNacs41.html#wp164275
M.
hope that helps rate if it does
I can't find the patch mentioned in the link named applAcs_4.1.1.23_ACS-4.1-CSTacacs-CSCsg97429.zip.
I can only find one called Acs-4.1.1.23.5-SW.zip
Is this the same patch as the one above ?
These are versions we are running. I have tryed to run the patch mentioned in the last message, but it still doesn't work. Do i need to configure something in the ACS ?
Application Versions
Cisco Secure ACS 4.1.1.23
Appliance Management Software 4.1.1.23
Appliance Base Image 4.1.1.4
CSA build 4.0.1.543.2 (Patch: 4_0_1_543)
