David Stanford Thu, 02/21/2008 - 07:34
  • Cisco Employee,
Check the RME Detailed device reports which should query the routers/switches for their serial numbers. However, keep in mind that for many routers you need to have the command "snmp-server chassis-id XXXXXX " (XXXXX as the serial #) for RME to get the serial number.
cpi Thu, 02/21/2008 - 08:16
Well I was able to find it but the information isn't right, but I will do what you said in your post. Thanks for getting back to me so quick
