server initiated connections, CSM - Default Gateway ?
Feb 21st, 2008
Hi !
I am trying to configure server-initiated connections. As the server needs to access several destinations - I need to configure a default gateway.
I did:
vlan 110 client
ip address 172.16.110.253 255.255.255.0
gateway 172.16.110.50
alias 172.16.110.254 255.255.255.0
vlan 130 server
ip address 172.16.130.253 255.255.255.0
alias 172.16.130.254 255.255.255.0
static nat xxx.xxx.xxx.xxx
real 172.16.130.10
static nat yyy.yyy.yyy.yyy
real 172.16.130.11
The server has configured the Alias address as a gateway - but the CSM does not send the request.
When I enter a "route xx.xx.xx.xx /24 gateway 172.16.110.50" command it works..
BUT...
I need to access several destinations - not only one...
Doesn`t it support a default-gateway configuration ?
I would really appreciate any help...
cheers
Hans
Jon Marshall Thu, 02/21/2008 - 06:53
Hans
There is another forum in NetPro
Data Centre -> Application Networking.
You will probably get help much quicker in that forum as that is where the CSM experts hang out.
Jon
