501 RDP over VPN
Feb 21st, 2008
I can connect to the vpn but I am having trouble accessing anything on the inside. Any help is appreciated.
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password ****
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list inside_outbound_nat0_acl permit ip any 192.168.1.0 255.255.255.224
access-list inside_outbound_nat0_acl permit ip interface inside 192.168.1.0 255.255.255.224
access-list outside_cryptomap_dyn_20 permit ip any 192.168.1.0 255.255.255.224
access-list vpn3001_splitTunnelAcl permit ip interface inside any
access-list outside_cryptomap_dyn_40 permit ip any 192.168.1.0 255.255.255.224
pager lines 24
logging on
logging timestamp
logging trap informational
logging host inside 192.168.1.2
mtu outside 1500
mtu inside 1500
ip address outside X.X.X.X 255.255.255.0
ip address inside 192.168.1.1 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip audit info action alarm
ip audit attack action alarm drop
ip local pool ippool 192.168.1.8-192.168.1.18
pdm location 192.168.1.2 255.255.255.255 inside
pdm logging informational 512
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 X.X.X.X 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto dynamic-map outside_dyn_map 40 match address outside_cryptomap_dyn_40
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup vpn address-pool ippool
vpngroup vpn dns-server 192.168.1.3 X.X.X.X
vpngroup vpn split-tunnel vpn3001_splitTunnelAcl
vpngroup vpn idle-time 1800
vpngroup vpn password XXXXX
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 inside
dhcpd dns X.X.X.X X.X.X.X
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
acomiskey Thu, 02/21/2008 - 07:11
  • Green, 3000 points or more
1. Don't use the same subnet for you vpn pool that you use for your inside.
2. add "isakmp nat-traversal"
peteb41976 Thu, 02/21/2008 - 08:40
Still no go.
enable password XXXX
names
access-list vpn3001_splitTunnelAcl_1 permit ip any any
access-list outside_cryptomap_dyn_80 permit ip any 192.168.1.0 255.255.255.224
access-list vpn3001_splitTunnelAcl permit ip any any
pager lines 24
logging on
logging timestamp
mtu outside 1500
mtu inside 1500
ip local pool ippool 192.168.1.8-192.168.1.18 mask 255.255.254.0
pdm location 192.168.1.0 255.255.255.224 outside
pdm history enable
arp timeout 14400
http server enable
floodguard enable
crypto dynamic-map outside_dyn_map 60 set transform-set ESP-3DES-MD5
crypto dynamic-map outside_dyn_map 80 match address outside_cryptomap_dyn_80
crypto dynamic-map outside_dyn_map 80 set transform-set ESP-3DES-MD5
isakmp nat-traversal 30
vpngroup vpn split-tunnel vpn3001_splitTunnelAcl_1
vpngroup vpn password password XXXXX
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd enable inside
terminal width 80
acomiskey Thu, 02/21/2008 - 09:29
192.168.1.8-192.168.1.18 is still part of 192.168.1.0/24.
peteb41976 Thu, 02/21/2008 - 09:40
Okay, how's this?
enable password XXXXXX
names
access-list inside_outbound_nat0_acl permit ip any 192.168.2.0 255.255.255.224
access-list outside_cryptomap_dyn_40 permit ip any 192.168.2.0 255.255.255.224
access-list vpn_splitTunnelAcl permit ip any any
pager lines 24
logging on
logging timestamp
mtu outside 1500
mtu inside 1500
ip local pool ippool 192.168.2.8-192.168.2.18 mask 255.255.255.0
pdm history enable
arp timeout 14400
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd enable inside
terminal width 80
peteb41976 Thu, 02/21/2008 - 09:29
names
pager lines 24
logging on
logging timestamp
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
http server enable
floodguard enable
vpngroup vpn password password XXXXXX
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd enable inside
terminal width 80
