ASA's outsode interface can be "pinged" should it be?
Feb 21st, 2008
Hi, from the Internet I can ping our ASA's outside interface, should this be liek if not how can I stop it?
abinjola Thu, 02/21/2008 - 07:40
yes by default its allowed
Add this to block :-
ASA5510-Single(config)# icmp deny any echo outside
whiteford Thu, 02/21/2008 - 08:48
Does it matter if it's "pingable" or should it locked down?
I only use the ASDM and added the rule at the top of the list as a deny and I could still ping outside interface?
abinjola Thu, 02/21/2008 - 08:59
well sometimes you might need to allow pings to outside Interface for troubleshooting there is not harm to allow excho request to outside Interface, moreover if your ICMP has configured rate limiting on ICMPs then you don't need to worry about the flood hitting ASA
In ASDM you might have added rule in ACL to deny this but this isn't a transitting traffic so ACL does not work for this
