restore (3745)router to boot to IOS
Feb 21st, 2008
I have a 3745 router that does not want to load the IOS. I am beginning to think that it is trashed. It continually hangs up when I try to boot from the default IOS. I have loaded a new IOS on the flash and tried to force it to boot to flash:file. It gives me the error message.
*** Unknown External CPU Interrupt ***
Stacked Cause = 0x4000, Stacked Status Reg = 0x34018003
Current Cause IP[7..0] = 0x40, Current SREG IP[7..0] = 0x80
I have included the entire boot process in the attachment. I do not want to walk away from this b/c I really do not want to buy new but I am out of ideas and have not found any docs that go beyond what I have already tried.
vaisharm Thu, 02/21/2008 - 07:43
If you have any modules installed on the router, take those out and then try to boot the router. Try the following from ROMMON:
Step1:
ROMMON1>boot
OR
ROMMON1>boot flash:c3745-is-mz.122-15.ZJ3.bin
If it fails:
Step2:
ROMMON1>confreg 0x2142 << This would ignore the startup config.
ROMMON1>reset
Follow step1 after the router drops back into ROMMON.
Step3:
If it still does not work, try reseating the DRAM and follow the same process.
Do capture everything and post it.
HTH,
Vaibhav
Richard Burts Thu, 02/21/2008 - 07:56
aaron
You provided good information about the issue in the file that you posted. I took a quick attempt with the error message to use the Output Interpreter and the Error Message Decoder on the Cisco site but neither tool came up with anything.
I am not sure about it but if I were guessing I would guess that there is a hardware failure of some kind. If the router were under a maintenance contract I would open a case with Cisco TAC. Would I assume from your message that a TAC case is not possible?
Rick
uwhadministrator Fri, 02/22/2008 - 06:56
It is no longer under smartnet. The results i got from the previous post were identical. as follows. There is only one module that is installed in the unit. It looks like it the back plane interface card with slots for a second CF card and the only console port. I have even tried moving the cf card to the slot0: to boot up with same results. Any ideas???
rommon 2 > dir flash:
program load complete, entry point: 0x80008000, size: 0xb2a0
Directory of flash:
2 20521424 -rw- c3745-is-mz.122-15.ZJ3.bin
5013 316942 -rw- CP79020101SCCP030530B.sbin
5091 307479 -rw- CP79050101SCCP030530B.sbin
5167 308284 -rw- CP79120101SCCP030530B.sbin
5245 369950 -rw- P00303020214.bin
5336 333822 -rw- P00403020214.bin
5419 47904 -rw- S00103020002.bin
5432 3624 -rw- admin_user.html
5433 546317 -rw- admin_user.js
5567 301298 -rw- ata18x-v2-16-ms-030327b.zup
5641 824044 -rw- cmterm_7920.3.3-01-02-021.bin
5843 16344 -rw- dom.js
5848 6146 -rw- ephone_admin.html
5852 496521 -rw- music-on-hold.au
5974 3503 -rw- normal_user.html
5975 76024 -rw- normal_user.js
5995 2267 -rw- telephony_service.html
5997 9968 -rw- xml-test.html
6000 2453 -rw- xml.template
6001 660 -rw- vlan.dat
6002 18971964 -rw- c3745-is-mz.123-6.bin
10634 7799 -rw- demo-config
10636 10645 -rw- houston-old.cfg
rommon 3 > boot flash:c3745-is-mz.122-15.ZJ3.bin
program load complete, entry point: 0x80008000, size: 0x13920b4
Self decompressing the image : ############################################################################################################################################################################################################################## [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0002F7 0X005F3C00 C3745 Mainboard
0X00280000 OIR memory
0X000F3BB0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X00B787B0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 12Mb.
Using 9 percent iomem. [12Mb/128Mb]
