server initiated connections, CSM - Default Gateway ?
Feb 21st, 2008
Hi !
I am trying to configure server-initiated connections. As the server needs to access several destinations - I need to configure a default gateway.
I did:
vlan 110 client
ip address
vlan 130 server
ip address
static nat
static nat yyy.yyy.yyy.yyy
The server has configured the Alias address as a gateway - but the CSM does not send the request.
When I enter a "route xx.xx.xx.xx /24 gateway" command it works..
I need to access several destinations - not only one...
Doesn`t it support a default-gateway configuration ?
I would really appreciate any help...
pknoops Thu, 02/21/2008 - 17:24
Hi Hans,
Another way to do this is to create a dummy serverfarm for the outbound requests.
Something like this:
Nat pool test netmask
vserver outboundnat
virtual any
serverfarm routeout
vlan servervlan
serverfarm routeout
no nat server
nat client test
predictor forward
When a device in the server vlan initiates a connection it is caght by the vserver and
will be client natted to the natpool address and routed out by the CSM.
This is how many people setup outbound server initiated connections.
Gilles Dufour Fri, 02/22/2008 - 00:44
do you have another gateway configured on a different vlan ?
The CSM will only use 1 gateway. The first one configured or the first one to respond to arp request after reboot or failover.
So, if you have another gateway configured, that's the one the CSM will use to forward the traffic.
Configuring a vserver with a 'predictor forward' serverfarm won't change anything if this is a routing issue.
