1721 router+4esw WIC+IOS firewall
Answered Question
Feb 21st, 2008
I've a 1721 cisco router(192.168.157.254) with a 4port10/100 wic installed.
Is possible to filter using IOS firewall if wic address and lan address are similar? I know that is they have diferent ip addresses is possible, but if they are in the same LAN?
For example:
A server(192.168.157.10) connected directly to the router's wic FILTER and out using LAN interface.
Is possible?
best regards
Correct Answer by didyap about 9 years 5 months ago
Yes, the IOS firewall can filter out even if the LAN and wic addresses are similar. Following link may help you
http://www.cisco.com/en/US/docs/ios/12_4/secure/configuration/guide/schfirwl.html
Overall Rating: 5 (1 ratings)
