Codec while script is runnig
Feb 21st, 2008
Hi !
I have installed an IPCC 4.0 with g.711 codec...
Calls to the IPCC pilot number (7050) from another branch are running with g.711 while they're in the script.. this is a problem because of the bandwith..
I heard that it's possible to use the Transcoding resource from CallManager (4.2) to make the calls running with g.729.
Is it possible ?
How ?
Thanks.
Andrei.
