Maximum Number of IP Phones on a CME Router (SCCP+SIP)
Brandon Buffin Thu, 02/21/2008 - 09:04
  • Purple, 4500 points or more
Gabriel,
This maximum is the max number of IP phones (SIP or SCCP). Take a look at the following link. Notice that there is a case where the maximum number of SIP phones is less than the maximum number of IP phones.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme34spc.html
Hope this helps. If so, please rate the post.
Brandon
paolo bevilacqua Thu, 02/21/2008 - 14:48
  • Hall of Fame,
    Founding Member
Hola Gabriel,
notwithstanding the published documents, the CME system does not enforce the sum of SCCP and SIP phones could to not exceed the maximum number per type.
Moreover, for sccp, the actual configurable number is slightly higher than the published numbers.
So, you should be able to have a system having maximum sccp and sip phones simultaneously.
That would be most certainly a non supported configuration, and one that is difficult to maintain and to explain to users why certain phones do things in a way and others in another or not at all.
paolo bevilacqua Fri, 02/22/2008 - 06:33
  • Hall of Fame,
    Founding Member
I guess not, but only the TAC can answer this question.
