show crypto sa with module VAM2+ module
Feb 21st, 2008
HI,
On a Cisco router 7206VXR with a modul VAM2+, I'd like to know what is the signification of the value of VAM2+ in the "show crypto sa".
The example is below
Cerise#sh crypto ipsec sa
interface: Tunnel1
Crypto map tag: Tunnel1-head-0, local addr 10.254.101.1
protected vrf: (none)
local ident (addr/mask/prot/port): (10.254.101.1/255.255.255.255/47/0)
remote ident (addr/mask/prot/port): (10.254.101.2/255.255.255.255/47/0)
current_peer 10.254.101.2 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 2832, #pkts encrypt: 2832, #pkts digest: 2832
#pkts decaps: 2832, #pkts decrypt: 2832, #pkts verify: 2832
#pkts compressed: 2783, #pkts decompressed: 2783
#pkts not compressed: 49, #pkts compr. failed: 0
#pkts not decompressed: 49, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 10.254.101.1, remote crypto endpt.: 10.254.101.2
path mtu 1476, ip mtu 1476, ip mtu idb Tunnel0
current outbound spi: 0xFDA14883(4255205507)
inbound esp sas:
spi: 0x4950D1CB(1230033355)
transform: esp-256-aes esp-sha-hmac ,
in use settings ={Tunnel, }
conn id: 2009, flow_id: VAM2+:9, crypto map: Tunnel1-head-0
sa timing: remaining key lifetime (k/sec): (4446452/443)
IV size: 16 bytes
replay detection support: Y
Status: ACTIVE
inbound ah sas:
inbound pcp sas:
spi: 0xB30E(45838)
transform: comp-lzs ,
sa timing: remaining key lifetime (k/sec): (4446452/442)
Status: ACTIVE
outbound esp sas:
conn id: 2010, flow_id: VAM2+:10, crypto map: Tunnel1-head-0
IV size: 16 bytes
Status: ACTIVE
outbound ah sas:
outbound pcp sas:
spi: 0xAA11(43537)
sa timing: remaining key lifetime (k/sec): (4446452/441)
Status: ACTIVE
