CM5 normal cpu usage?
Feb 21st, 2008
The cluster in question is running CM5.1
The normal operation cpu percentage is around 70-80% on the pub and 60-70 on the sub. There are approximately 450 phones registered.
Is it normal to see this level of cpu usage?
The process that seems to be hogging most of the cpu is "hostagt" with around 45% on the pub. What is this for?
sparklemotion Mon, 05/05/2008 - 12:32
I am having the same thing, not sure if it is abnormal. I am running detailed CDRs and am not sure if it is related? anyone have any insight?
gogasca Mon, 05/05/2008 - 20:42
  • Green, 3000 points or more
I dont have enough info to tell you if in your system that is normal CPU or not
(CCM version, Model, Services, days running, Space, Phones registered...etc etc etc) but.........
hostagt is for Host Resources Agent service
that service is related to SNMP
I have seen this issue in the past with other customers and resetting the SNMP service and
MIB2 service helps...
mhurley131 Tue, 05/06/2008 - 03:39
I ended up scheduling a reboot after hours and that fixed the problem.
