CSM Deployment to a 2811 Failure
Feb 21st, 2008
I manage 213 2811s with CSM and there is one site that fails everytime I go to deploy changes to it. It fails with, "Failed to parse response from device. Cause: Upload configuration failed since the CT response from device XXXX is malformed. JDOM exception while parsing XML input stream."
I have tried reimporting the policies but I get the same error on deployment. Any ideas?
innout1948 Wed, 02/27/2008 - 13:10
I tried to look it up in the Bug Toolkit and it says it is only available to Cisco employees. The router in question is running c2800nm-advsecurityk9-mz.124-15.T1.bin with 12.4(13r)T ROM. What version fixes it?
