Hieu Cao Thu, 02/21/2008 - 12:51
What router are you using? Packets dropped while going in or out the LAN int.? Do you have QoS setup?
Try this under the LAN interface.
hold-queue 500 in
(increase as needed if having enough mem to support it)
hth,
hieu
manik.palekar Thu, 02/21/2008 - 19:28
flash:c3845-advipservicesk9-mz.124-3d.bin
i am facing this problem during extended ping from LAN int to outside.But its working fine from LAN switch.I have configured hold-queue 500 in ..lets c ..thnaks
Paolo Bevilacqua Thu, 02/21/2008 - 14:21
A recent IOS version, and
buffer tune automatic
Works beautifully!
