Cisco IP Telephony Design Specialist
Feb 21st, 2008
I have my CCVP. I want to take the UCAD exam to get my Cisco IP Telephony Design Specialist cert. However, the prereq. states that you need a CCDA. Does that apply if you have a CCVP?
Thanks!
Joe
erikjustinlee Thu, 02/21/2008 - 11:22
Unfortunately yes it does. For any of the "Design" Specialists it will require you to have your ccda even if your a ccie.
Been there, done that :)
Erik
JOEALBERTINI Thu, 02/21/2008 - 12:01
Thanks Erik!!
I even called the toll free certifications line, and the guy told me since I have my CCVP, "I don't think you need the CCDA", you should be fine". I wasn't comfortable with his answer.
You saved me much aggravation...... Thanks again.
