FWSM Route Configuration
Feb 21st, 2008
I'm getting this log on my FWSM. Does anybody know why?
<166>Feb 21 2008 10:55:58: %FWSM-6-110001: No route to 192.168.101.1 from 192.168.8.10
I have the following config:
FWSM Version 3.2(4) <context>
firewall transparent
hostname ADMIN
interface Vlan109
description "Admin Link for Context ADMIN"
nameif REMOTE-ACCESS-IF
bridge-group 9
security-level 0
interface Vlan608
description "Outside interface for VLAN 8"
nameif V608OUTSIDE
bridge-group 8
security-level 0
interface Vlan8
description "VLAN 8 inside interface"
nameif V8INSIDE
bridge-group 8
security-level 100
interface BVI8
description "Intervlan link V8-V608"
ip address 192.168.8.10 255.255.255.0
interface BVI9
description "Administrative Interface for Context ADMIN"
ip address 192.168.107.18 255.255.255.248 standby 192.168.107.19
object-group network test
access-list vlan8 extended permit ip any any
access-list vlan8 extended permit icmp any any
access-list inside_traffic extended permit ip any any
access-list inside_traffic extended permit icmp any any
logging enable
logging timestamp
logging monitor debugging
logging buffered debugging
logging trap debugging
logging history debugging
logging asdm informational
logging host REMOTE-ACCESS-IF 192.168.101.100
mtu REMOTE-ACCESS-IF 1500
mtu V608OUTSIDE 1500
mtu V8INSIDE 1500
icmp permit any REMOTE-ACCESS-IF
icmp permit any V608OUTSIDE
no asdm history enable
arp timeout 14400
access-group vlan8 in interface V608OUTSIDE
access-group inside_traffic in interface V8INSIDE
route REMOTE-ACCESS-IF 0.0.0.0 0.0.0.0 192.168.107.17 1
snmp-server host REMOTE-ACCESS-IF 192.168.101.100 community xxxx
snmp-server community xxxx
snmp-server enable traps snmp authentication linkup linkdown coldstart
snmp-server enable traps syslog
telnet timeout 5
ssh 192.168.101.100 255.255.255.255 REMOTE-ACCESS-IF
amritpatek Wed, 02/27/2008 - 13:08
You can configure a static route from 192.168.8.10 to 192.168.101.1. If you do not require a connection from 192.168.8.10 to 192.168.101.1 and you are getting this log check if some application is trying to access address 192.168.101.1.
