SDM won't start
I have upgraded our 2811 router with the lastest IOS and CME. Everything works nice. I used the SDM setup.exe file to install SDM 2.5 on to the router. So far everything good. These files was added:
54 1038 Feb 21 2008 19:22:26 +01:00 home.shtml
55 2748 Feb 21 2008 19:22:26 +01:00 sdmconfig-2811.cfg
56 112640 Feb 21 2008 19:22:28 +01:00 home.tar
57 527849 Feb 21 2008 19:22:28 +01:00 128MB.sdf
58 1505280 Feb 21 2008 19:22:32 +01:00 common.tar
59 6389760 Feb 21 2008 19:22:42 +01:00 sdm.tar
When I now type http://router-ip/ in my browser this happens:
1. Asks for username and passord
2. "The webpage cannot be found"
This is the url now: http://router-ip/archive/flash:home/html/home_aux.shtml
Any suggestion?
By the way, in my router config this is set: "ip http path flash:"
Hieu Cao Thu, 02/21/2008 - 13:20
Ruben,
Do you have a local user account with privilege 15 in your router? Use this acct. to login SDM.
Try removing "ip http path flash:"
Make sure that you've enabled http in your router:
ip http server
ip http authentication local
ip http secure-server
hth,
hieu
Hieu Cao Fri, 02/22/2008 - 09:56
Did you back up those files before you replaced them? If you did, then copy those old files back.
Have you tried accessing the router from a different workstation / browser? I think that SDM is dependent on certain java version for it to work correctly. Try installing a more updated java version on your computer.
Richard Burts Fri, 02/22/2008 - 10:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ruben
I would suggest that instead of http:// that you try https://
Rick
nathanchoate Mon, 03/03/2008 - 08:13
I have same issue here. Has anyone resolved this. I do have the config entries suggested here from previous config. I can login then it fails. perhaps its java as someone suggested but I tried an older sdm and stil had no luck.
Richard Burts Mon, 03/03/2008 - 13:51
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Nathan
It would help if you would post the config and also post the output of show flash.
do I understand correctly that you point your browser at the IP address, that it opens and you get a login prompt, that you input your ID and password, and after logging in there is some failure? What error message do you get?
Rick
nathanchoate Mon, 03/03/2008 - 14:58
Turns out its a bug in the IOS version 12.4-18
Here is a result of my case from TAC. I ended up connecting via installing client on my workstation and connecting there.
Hello Nathan,
Please check the following Bug:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsl67527
Below is my contact infomation in case you need it.
Best regards,
NMS Team
Cisco TAC Engineer
Richard Burts Mon, 03/03/2008 - 15:07
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Nathan
That is good to know. Thank you for posting back to the forum and indicating that you had a solution and what the details of the solution were.
Rick
