CSS11501 Configuration Question
Feb 21st, 2008
I have two front end mail servers. I currently use the CSS to balance / failover OWA. I would like to set up the same thing for SMTP traffic as well. Can this be done? If so, is their a general template i can use for configuation assistance?
Gilles Dufour Fri, 02/22/2008 - 00:45
  • Cisco Employee,
if you are not using any particular HTTP functions (like url match or cookie stickyness), you can simply duplicate the config that you have for OWA for your SMTP traffic.
Simply change the port to the appropriate one.
Gilles.
