Dial peers - transfering voip incoming calls to another router
Answered Question
Feb 21st, 2008
Hello.
I am trying to transfer some of the incoming voip calls sent to one of our voice gateways(router) to another router, equipped with CME.
I tried to follow the concepts of inbound and outbound dialpeers and hairpinning (if I understood correctly) but with no luck.
Did anybody get this to work and has an example ?
Tks
Correct Answer by Paolo Bevilacqua about 9 years 21 hours ago
Well, there's a bit more than that. To be assured it works, you need an ip-to-ip GW image, and configure service voip, allow sip to sip connecions (or h323 if that's what youre using).
Overall Rating: 5 (1 ratings)
dvanzee@rgl.net Thu, 02/21/2008 - 13:25
I have transferred calls from one gateway to another over a PTP link; just make sure the destination-pattern is the IP of the next gateway. Also, make sure routing is setup properly.
Correct Answer
Paolo Bevilacqua Thu, 02/21/2008 - 14:11
gurzonijunior Mon, 02/25/2008 - 09:25
Belilacqua, a sharp shoot. it worked. I was missing the voice service voip allow h323 to h323 command in the router that needs to relay the calls (the 'middle' router) to the CME.
tks
