erasing config
Answered Question
Feb 21st, 2008
all our switches are in vtp transparent mode, do I need to issue the delete flash:vlan.dat to clear the configuration or just erase start?
Correct Answer by lamav about 8 years 8 months ago
Overall Rating: 5 (3 ratings)
lamav Thu, 02/21/2008 - 12:53
You havent specified the switch models, but typically you could use the following;
erase nvram to delete all files in nvram.
erase const_nvram to delete vlan database
erase startup-config to delete startup config
If so, please rate this post.
lamav Fri, 02/22/2008 - 06:45
Actually, you must specify the switch because it varies.
To erase the vlan.dat file on the 6500/6000 switches, issue the erase const_nvram: command. On the 4500/4000 switches, issue the erase cat4000_flash: command. On the fixed configuration switches, issue the delete flash:vlan.dat command.
andrewerowley Fri, 02/22/2008 - 08:36
The switches in question are 3750 and 3560 so I am guessing the delete flash:vlan.dat is required.
