WAAS - Dropping TCP Traffic
Feb 21st, 2008
I'm having issues with TCP traffic between my edge and my core. Using L2 redirection at my edge with a 4507 (l3) and L2 redirection at my core with a 6500Sup720. I have a dedicated VLAN for my WAE's at both sites.
I issue the 'sh tfo connection summary' on my Core WAE and I see the following:
Local-IP:Port Remote-IP:Port ConnType
HostAIP:45056 HostBIP:80 PT AD Int Error
Does anyone know what the 'PT AD Int Error' indicates?
Zach Seils Thu, 02/21/2008 - 17:04
Michael,
We'll need to collect some additional information to determine what is going on. Can we start with the following (assuming you can reproduce the condition):
1. Change the disk logging level to 'debug':
conf
logg disk prior debug
end
2. Enable TFO AD debugging;
debug tfo conn auto
3. Disable the debug:
un all
4. Send me the syslog.txt file from the local1 directory.
Would it also be possible to collect a packet capture from the WAE showing this state?
Zach
