Interface Shutdown
Answered Question
Feb 21st, 2008
Hi There;
Is there a way I can configure the 2811 router so that if a serial interface was to go down it will then shut down its own E1 interface?
Overall Rating: 5 (2 ratings)
austindaz Thu, 02/21/2008 - 15:06
Hi there;
IS there then a way of making the E1 interface unshut if the serial interface was to come back up - or would that require manual intervention?
thanks
austindaz Thu, 02/21/2008 - 15:15
Hi There;
Does that require a specific IOS version to run?
austindaz Thu, 02/21/2008 - 15:36
We're about to purchase the router - so I'll need to check that. Do you have an example script I could review?
thanks
austindaz Thu, 02/21/2008 - 16:00
Thanks very much - you've been a great help
Correct Answer
Joe Clarke Sun, 02/24/2008 - 10:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I just did this for someone else. See
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dddb7ff/6#selected_message
I outlined examples that will work with 12.4T (using Enhanced Object Tracking) and code prior to 12.4T using syslog.
