Archive Mgt - Config changes
Answered Question
Feb 21st, 2008
I'm seeing CiscoWorks update the Archive based on the following changes in the configuration. When I do a compare of configs is says that the clock period has changed???
ntp clock-period 36028913
Is this normal, I'm not too sure what this command really does?
Correct Answer by Joe Clarke about 9 years 2 months ago
This command should be ignored by config archive. However, we have seen some instsnaces where certain device classes did not have this command in their list of excluded commands. It's easy to fix. Go to RME > Admin > Config Mgmt > Exclude Commands, and add "ntp clock-period" to the list of excluded commands for this device type.
The typical list for IOS devices is:
end,exec-timeout,length,width,certificate,ntp clock-period
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Thu, 02/21/2008 - 17:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
