Warning message
Partial routing updates with MPLS via BGP
Feb 21st, 2008
I am having an issue with only receiving a partial routing table at a new site connected via Verizon's MPLS service.
The routing protocol used for PE-CE is BGP. The routers involved are all 2821 running the same version of software - v12.4(11).
The new site receive route information for most of the existing sites, but does not get route info for a few specific sites. The BGP routing configuration is the same at all site except for the site specific information.
Basically, Site D is a new site. Site D receives routing info. for sites B and C, but not A.
Sites A receives route info for sites B and C, but not D.
A trace route from A to D, dies after the PE device at site D. A trace route from D to A fails imediately.
A sample of the BGP routing config is below:
router bgp 1
no synchronization
bgp log-neighbor-changes
redistribute eigrp ### metric 20
neighbor x.x.x.x remote-as #####
no auto-summary
I'm not sure if the issue is with our routing, or if Verizon's PE is not passing all the routing updates.
Anyone has any sugestions?
Joseph W. Doherty Thu, 02/21/2008 - 17:59
For the new site D, use the show bgp neighbor command to see the routes being received from the provider peer and to confirm what site D is sending to the provider (you didn't mention whether sites B and C see D).
mike.rootvik Thu, 02/21/2008 - 21:20
Sites B and C are receive route info for both Site A and D.
Sh BGP on A show no information for site D, and Sh BGP on site D show no information for A.
Both A and D show BGP entries for sites B and C.
Joseph W. Doherty Fri, 02/22/2008 - 05:28
Assuming there's no inbound BGP filters, route maps, etc. on either site A and D, then if you haven't already, you could try a bgp clear inbound at both sites A and D. If routes still not there, might be time to contact MPLS vendor.
mike.rootvik Fri, 02/22/2008 - 08:18
Unfortunately, the bgp clear did not work. so I'll be calling the vendor.
thanks for the hrlp.
Joseph W. Doherty Fri, 02/22/2008 - 08:36
If possible, let us know about problem resolution.
Mohamed Sobair Sun, 02/24/2008 - 11:10
  • Gold, 750 points or more
1st, if you are running bgp as a CE-PE routing protocol, the above shouldnt be the config sample. why are you redistributing Eigrp?
Could you check you BGP routing table at Site-A & D.
The Symptoms appears as there is no route back from Site-D to A.
This could be due to a lot of problems at the service provider, whether the Networks at Site-D are not advertised through MP-BGP or it could be a route-target issue at the service provider.
Pls let us know how you routing table look like at both sites.
Mohamed
royalblues Mon, 02/25/2008 - 01:23
  • Green, 3000 points or more
Can you try configuring the following under the BGP session at D
router bgp 1
neighbor x.x.x.x allow-as in
Narayan
