CM 5.1 vice gateway with two different isdn provider
Feb 21st, 2008
I have a CM 5.1 installation, my client has got two different isdn providers(isdn 30 channel) with E1 line and which are conneted to a single voice gateway. could you please tell me which is the recommanded configuration for this(mgcp or h323)?
manoj.varghese Fri, 02/22/2008 - 00:42
Thanks for the reply, but my real concers is if i use two different isdn providers on the same voice gateway, does this make any clocking issue on the router?
jconi Fri, 02/22/2008 - 01:02
The clocking is based on the "network-clock-select" and "network-clock-participate" IOS commands, and doesn't matter with MGCP or H323.
Choose your favourite protocol.
rgds
jp
pcameron Fri, 02/22/2008 - 07:11
  • Cisco Employee,
Clocking will be a concern only if the two service providers are ultimately using a different master reference for their networks - there will be a slight difference between the two. This would show up as clock slips on one of the E1 interface. If the two Service providers are synced up to a common reference , then it should be OK.
