Upgrade CCM 3.3(3) to 4.2
tony.hanson
I'm looking for the best path to do an upgrade from 3.3(3) to 4.2. according to the documentation this would require a 2 step upgrade, so I was wondering would it be better to upgrade to 3.3(5) or 4.1(3) before going to 4.2.
Any thought? Is there anyone who went directly to 4.2 from 3.3(3)?
Jaime Valencia
actually it's the same anyone you choose, if you choose the 3.3(5) then you will need to order the upgrade cds for 4.2(x)
if you choose 4.1(3) then you will need to ask for the upgrade disks to 4.1(3) and then go to 4.2(x)
if you have any of the above upgrade CDs handy i'd go that way.
most of the 3.3(x) ones i did were going to 4.1(3) (since i had those CDs) and then up to 4.2(3)
java
if this helps, please rate
