Advice about L2 security features
Feb 21st, 2008
Guys, I'm about to start a replacement of access switches project from the
current 2900's to 3750 stacks. We're deploying almost all of the L2 security
features and although I'm well adept to all of them technically, this is the
first time I'm going to work with them outside of a lab. I'm keen to know
what kind of extra resource time would they take up and what problems we'll
run into. Any expereriences you guys have from the past which will aid me to
create an appropriate work plan for management to look at would help. My
management wants to know how many engineers should be involved and how much
of their time would be taken up over the next few months
In particular, we're deploying these. Please make recommendations of other
security features I should look to deploy other than these:
1) port security - allow only 1 mac address to be seen on a port
2) DHCP snooping
3) Dynamic ARP inspection
Thank you in advance!
Edison Ortiz Thu, 02/28/2008 - 10:02
  • Hall of Fame,
    Founding Member
4) BPDUGuard on ports with portfast enabled.
__
Edison.
Mohamed Sobair Thu, 02/28/2008 - 11:42
  • Gold, 750 points or more
Edison have slit excellent point about L2 Security feature, I just added this post because I had some confusion on the past about implementing whether (root guard) or bpdu guard on at interface.
Afaik, root guard , will still allow a switch to receive BPDUs although it wont allow superior hellos, but still its allowed, rather (Bpdu guard) would put the port immediately into err-disable state once its receives BPDUs.
Mohamed
