Reestablishing a Broken CallManager Cluster SQL Subscription
Feb 21st, 2008
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a00801d11a6.shtml
Unfortunately, I checked the box in step 3, Is there any way to appear the SQL Server Wizard again?
I need reestablish the relationship between the Publisher and the subscriber.
some ideas. please.
Avner Izhar Fri, 02/22/2008 - 23:08
Try to get your hands on a dblhelper.exe utility, it is a specialized app for doing what you need. SQL enterprise admin might get tricky if you haven't used it before.
HTH, Avner.
